Jig Saw: mafell or . . .
abates
Hi All, I am looking for a new jigsaw.  Admittedly, I don't use a jig saw frequently, but when I do I need a good one.  I used to have a Bosch that worked well till I "upgraded" to a carvex.  I just sold the carvex and am looking for a new saw.  I don't need to spend the money on the mafell (nor do I want to) but I am willing to if it is the only decent saw on the market. I like to buy the best I can get but I am trying to learn to be more practical and that often the "best" is more about hype and marketing than reality. I often lean toward USA made, Swiss made, or German made tools.  Though I don't want to write off Chinese tools out of hand. I am open to suggestion for an $80 Bosch or whatever, but I need some feedback from people who have used them. Or should I just pull the trigger on the Mafell (and then my wife can pull the trigger on me:) Thanks!
Hilti is worth considering, but if you want perfection Mafell is the way to go from what I've heard.....
I like my Hilti and Carvex but have never used a Mafell.
Now a word from my betters........
You've not mentioned your preference in jigsaw format:  bodygrip or bow handled, corded or cordless.  Mafell are almost universally regarded as the creme de la creme, but are only available in corded bodygrip only.  It's also lacking some contemporary features/gimmicks such as automatic acceleration, flashing headlights etc.  However if performance is your primary consideration, you'd be hard pressed to find better.
Bosch are also highly regarded.  If heavy cutting in Max thicknesses =\< 6" is your requirement, then this is your machine.  If you prefer cordless body grips then the 18v Metabo has the slimmest (i.e. safest) circumference and those useful but functionally unnecessary headlights & accelerator function.
Without careful assessment of your requirements, it's difficult to make definitive recommendations.  Nevertheless, as you've undoubtedly already discovered, the green alternative offers not just dubious value for your hard earned readies, but rather disappointing performance in comparison to its peers.  My own Trion Saw was extremely disappointing:  expensive, toxic on blade life & incapable of consistently cutting at 90 degrees.
It's very difficult when you talk Mafell, then talk 80.00 Bosch? That makes little sense.
You already answered the question. Either get the 80.00, 130.00, 160.00 or the 260.00 Bosch. They are all nice enough, here are the D handle, Bosch makes two of these in barrel grip.
https://www.amazon.com/Bosch-JS260-...F8&qid=1504107684&sr=8-1-spons&keywords=Bosch+jigsaw&psc=1
https://www.amazon.com/Bosch-JS470E...F8&qid=1504107660&sr=8-2-spons&keywords=Bosch+jigsaw&psc=1
https://www.amazon.com/Bosch-JS365-...?ie=UTF8&qid=1504107810&sr=8-6&keywords=Bosch+jigsaw
https://www.amazon.com/Bosch-JS572E...?ie=UTF8&qid=1504107761&sr=8-5&keywords=Bosch+jigsaw
I have owned and used both versions of Festool, a couple of Bosch (including the JS572) and the Mafell.
The Mafell is hands-down the best jigsaw I have ever used - pristine cuts, square, powerful - pretty much everything you want in a jigsaw except a light (and no D handle if you prefer that style). It has several unique features that may or may not be important - like switching the blade to cut backwards or moving the shoe forward to cut exactly to the end of the machine -- think cuts outs or stopped cuts at the edge of a vertical piece like a wall. It also takes a special blade for square cuts in tight curves. All around a great saw - but not cheap. With most tools I buy, I forget about the price in time and appreciate the tool.
But, I also have the Bosch JS572 and it is also a really nice saw. Not as accurate as the Mafell, but pretty good and much cheaper.
I sold both of my Festools (Trion and Carvex) as I just did not like them as much -- actually I did like the Trion and thought it was very smooth, but I had to thin my herd of 4 jigsaws and I liked the Mafell and Bosch better. The Festool saws were OK, but I had a hard time getting straight and accurate cuts with mine with any consistency and square cuts proved challenging at times, especially when swapping blades and readjusting the blade guides.
Again, all nice saws, but the Mafell and Bosch performed better for me than the FT versions. YMMV.
I also own both the Trion and the Carvex. When cutting 2x materials, they're better than the Milwaukee I previously owned for square cuts, but still rather disappointing after listening to/believing in the Festool marketing hype.
I'm now thinking about putting both of them down the road and picking up the Mafell instead. The only reason I haven't pulled the pin is I prefer the D handle configuration.
I like the Trion because it's so smooth and the Carvex because it has built in lighting. But other than that, the blade guide adjustment on both is a PITA and neither one cuts absolutely square in thick materials.
Hi all, thanks for pushing me to clarify what I am looking for. My Bosch was a d-handle and I didn't realize until I went to the barrel grip of the carvex that I like the starter and speed control of a trigger switch on the d-handle.  The carvex switch was hard to reach.  But with the start button being what it is, I did like the barrel grip quite a bit.  I guess grip is not a big deal to me.
Gimmicks are not important to me (lights, acceleration before start, etc). Most of the blades I use are small fine cutting wood blades for sink cutouts in counter tops, cutting out electrical access in the back of cabinets, cutting jigs for router templates, or cutting corbels.  I am a professional woodworker, but again, I don't use the jigsaw a ton.  It's just that when I do use it, I want it to work well.  Never had the results that the carvex promised and it seemed like every time I used it I broke two blades from the heat build up on those guides.
I will continue to think on it.  What I do with a jig saw tells me I only need a cheap tool, but my aversion to cheap tools tells me I need the mafell. Sometimes I hate being a consumer. . .
If I would by a jigsaw it would bee a Mafell
But I would never get rid of my carvex cordless
with its attachments :)
For my line of work being cordless is a great help
Jozsef
For what you described ,one of the Bosch saw should be more than adequate.
Sure,  the Mafel is better . But it comes at a price , which you seem to have reservations about. Nothing wrong with that; but this is like everything else . Rarely will you find a high quality widget at a cut rate price.
The Bosch represents a good value , and why they likely outsell the other two German brands ten to one.
If I was buying another jigsaw and I didn't want it to be cordless and I didn't want it to fit in a CMS module and I didn't care that there was no warranty support for it in Oz ... I'd seriously consider the Mafell.
On reputation the Mafell seems the most capable, but I've never put my hands on one!
And if one is OK with a barrel grip.
And if one is OK with getting it flown in from Germany.
In 230v land it seems ideal, but I would suggest a Bosch may be enough for most things.
The p1cc is a nice jig saw, and I was cutting the cement board with the hitachi carbide tipped blades last weekend.
One feature that is nice is putting the bade in backwards. This came in handy when I needed to make an electrical hole next to a wall (~4"away) as I was able to run the saw backwards for 1/2 of the hole.
That feature is only available with a p1cc. Whether one needs that is another story, and if I had planned ahead then I would not have needed to make the hole in-situ.
OK, so I have whittled it down to the Mafell p1cc or the Bosch JS572eb.  Does anyone have any thoughts about this comparison.  The Bosch is Swiss made.  I handled it in the store today and while it looks nice, the blade release handle looks like it will break at some point and tilting the base was kind of a PITA.  But I like the light, I like the Swissiness of it, and I like the price.  Now, I spoke to a Mafell dealer and I REALLY LIKE that the saw is meant to be repaired.  That is, if something goes wrong, parts are available vs throwing it away and buying a new one.  I like the tilting base feature.  I am still dubious about the hype of the "no-guide" system.  If I hazard a guess, a fresh blade will yield square cuts on most saws. . . And at 3x the price of the Bosch, well, you understand my hesitation.  Someone talk me into something please!
I was going to talk you into the Bosch too.
But now I need to take the contrarian stance.
It has the best guide system (which is idiot proof with no guides).
You can even out the blade in backwards and cuts in reverse)
A great angle base.
Takes the extra wide Mafell blades which are flex free.
The circle attachment works.
The only "extra" is the angle base.
You cannot wrong with either.
But the p1cc will not have you wondering... It is a stunning tool.
I have both of these saws and like them both - I think I gave some high-level comparisons in an earlier post. The Mafell is hands-down the best saw and the no blade guides is NOT a gimmick. The mechanism holds the blade securely and different than other tools. The plunge mechanism is much more robust than any other saw I have seen and this machine is just quality all around - the base is machined square, the bottom is machined to mate perfectly with the angle base, the DC is better than anything out there for a jigsaw, it comes with a parallel guide that works and also acts as a small circle cutter and I can go on and on.
Nothing wrong with the Bosch - I like it and use it - but I use it more for rough work if I do not want to mess up the Mafell like cutting stone or steel, etc... Not that the Mafell could not handle it, but I try to relegate it to wood-cutting duties only. I can do joinery-quality cuts with this thing.
Here are some videos of this saw in action I filmed after I got it...
Unfortunately no...I proved that to myself on the Milwaukee, on the Carvex and on the Trion. This is especially the case as the stock gets thicker or if you're cutting circles or rounding corners on tables or countertops. As you side load the saw the blade flexes and the cut is no longer square.
Please understand that this post is not attacking any brand.  Nor am I attacking the ability of individuals to operate whatever saws they operate.
After reading so many posts here about jigsaws I honestly amazed at the amount of money that people spend for them.  Whatever brand.  Looking for the holy grail of perfect cuts, dust collection, perpendicularity, etc.
The tool operates a a blade that is usually only supported at the top and that cuts thru the workpiece vertically.  It is designed to cut cuts and follow a line.  The hand that controls the tool is located aft of the blade.  When cutting curves - especially cutting tighter curves - if you are not pivoting directly over the blade there will be a tendency to sweep and deflect the blade.  This is true for any blade.  Manufacturers had tried to counter this by placing knobs on top of the saws over the blades to help pivot it.  The have come with blade support mechanisms.  They have come up with thicker or specially shaped blades.
To get the most out of any jigsaw you own you need to learn to pivot it and turn it on the axis of the blade.
Very good point Peter.
There are enough idiot-proof features (like the lack of guides) on the saw in question that make it easier.
But I could also likely stand having greater level of skill.
Whether that saw is needed is uncertain, but my reasoning was that I wanted every advantage to help ease the process.
At this point it is becoming a bit difficult for me to keep blaming the equipment on lack of quality results... [blink]
