Tim Raleigh said:
Jon:
Looks good.
Can you give some background on the design?
It looks good, just wondering how you arrived at the stepped design.
Tim
Tim, as far as design, the client wanted as much book storage along that wall as possible, I probably could have stretched the cabinets to the window casing, but I felt it would have been too crowded. Could have gone to the ceiling, but the cabinets barely made it up the third floor as they were!
Typically, if anything is over 8' long, I like to either bump it out, or bump it in. I do this partly out of habit and partly because I like how crown looks when you put breaks in it. The out o habit part comes from installing lots of Prefinished jobs where the trim only comes in 8' lengths...
Finish is M.L Cambell conversion varnish, with two coats of primer. I spec out conversion varnish on all of my jobs because I'm not sold on the durability of lacquer on white cabinets. Like I said, I install a lot of Prefinished cabinets, most of which are lacquer. When I go back to jobs for tune ups, I cringe at the beating cabinets take and the lack of protection from lacquer. Just my opinion.
The beads are attached, as I was matching existing cabinetry in the house. Not to mention its much faster.
Thanks for the feedback guys. Hope this helps with your questions.
Jon
