DIY WoodWerx Member Joined Mar 31, 2017 Messages 180 Dec 21, 2019 #1 Looking for a permanent dust extractor for my miter station. Will the CT Sys be good for the Kapex?
C ChuckS Member Joined Sep 7, 2015 Messages 6,149 Dec 21, 2019 #2 Any system (even a shop vac) used with a dust deputy AND a 36mm hose (not too long) is good for the Kapex.
C chrisrosenb Member Joined Sep 1, 2007 Messages 1,232 Dec 21, 2019 #3 Unless you put a small cyclone between the Kapex & CT Sys, the small bag in the CT Sys will fill up very quickly.
B Birdhunter Member Joined Jun 16, 2012 Messages 4,108 Feb 26, 2020 #4 I use a dedicated Midi. The CT Sys is way too small.
semenza Member Joined Jun 24, 2007 Messages 10,301 Location Fingerlakes Region NYS Feb 26, 2020 #5 Not only will it fill quickly it has less suction than the other vacs. CT-Sys 106cfm, Mini/Midi 130cfm, CT26 36 48- 138cfm. More is better for the Kapex. Seth
goko Member Joined May 22, 2016 Messages 47 Feb 27, 2020 #6 Make sure you use the big hose, that goes on the outside on the mouthpiece on the Kapex. Much more effective than the small 27 mm.
