newinwood said:
I did asked about this problem on last ww show at Festool booth, but got answer that CTMini is not good for Kapex? Is this true?
Oh, back to the original poster's question. The reason why you were told this, is due to a bureaucratic rule within UL regulations for vacuums (UL1017), and Festool is bound by these regulations. If you ask Festool this question, they are required to tell you that it can't be done.
The UL1017 rule stems from a paragraph in the National Electric Code (NEC) that states that no single appliance is permitted to draw more than 80% of the total capacity of a circuit. However, it is permissible for 2 or more appliances to draw a full 100% capacity of a circuit.
Therefore, you can legitimately plug both the CT vac and Kapex into the same duplex receptacle (2 receptacles by NEC definition). However, UL has made the ruling that with a tool plugged into a vac, it thereby becomes a single appliance, and as such, it must follow the 80% rule.
The power cord on a CT vac is rated for 20 amps (25 amps actually), the receptacle (half of the duplex) is also rated for 20 amps, and the wiring in the wall doesn?t know the difference whether one plug is used or two.
The other part of the equation that UL (and NEC) overlooks is that both the vac and the tool are variable loads, and rarely ever operate at their full nameplate amperage.
