jmbfestool
galwaydude18 said:Why does it always tighten up way way more than I initially tighten it then?
Mine does the same. I only finger tight mine and when I came to remove it, I couldnt get it off. I called festool because I was worried about doing damage with the amount of force I was applying, they told me it does happen and the solution was to get a hollow bar to stick onto the Alan key to give me more leverage. It worked but I found a small hairline crack appeared straight through the bolt head. So I had to get a new bolt.
It tightened the bolt slightly with Alan key after that time not with fingers and after some use the bloody thing still became super tight. So far brute force has removed it with out splitting the bolt again but I don't think the bolt will last.
