I've used your setup of kapex and stock blade to cut a couple aluminum pieces and it did not seem to affect the blade. Then a few months later I tried it again with some different aluminum and the blade definitely dulled and I had to go get it resharpened. So I believe it does make a difference in the type of aluminum and the amount. I have a nonferrous blade that I now take the time to put on. On the side of caution I also have a spark suppressor mounted on the vac I use. In your case, it sounds like you're probably cutting soft and thin Al so most likely you will be fine, at that slower speed that's already been suggested. If you're using a DC, you may want to disconnect it for the cuts, just in case a hot enough particle makes it in with your wood dust, if you leave it connected.
