Kidneyshaped Coffe table
festoolviking
Hi there everyone!
Here is my latest project: It's a coffetable that got me to use my OF-1010 a lot. I started by routing the edgetrim pieces in various diameters. After shamfering the inside of the trims (using a homebuilt routertable) I puzzeled and cut the trims, glued and nailed them to a big sheet of plywood. Used the PS-300 to cut close to the edge and trimmed the sheet with a ball-bearing trimbit following the edgetrim. Then I added an extra sheet of ply for strength and looks. The legs are mitered and dominoed together aswell for to the top. Then sanded with my ETS-125 (wish I had a LS-130 for the edge). The wood is stained slightly white two times then clear-coated about four times.
festoolviking
I am surprised that no one responded or asked questions.
What is the wood and finish?  I hate rectangular things and this fits my fancy!
Austin Powers wants his shag pile carpet back ...
Table looks very clean and fresh. Nice  [smile]
The tabletop is made out of pine- plywood 8mm, two layers + the trim, also made of plywood. The legs are also made out of pine (we've got lots of that around here). I've then used ordinary woodstain and clearcoat. I'm going to build a smaller one soon, I'll try to take some pictures of the process then.
Festoolviking
Kev,as you can see your work?
My work is non existent at the moment ... my day job (IT) is taking up all my time and even an outside shed build is hampered by rainy weekends  [sad]
