Knee pads
neeleman said:
My favorites which will fit in the knee inserts of my trousers. They are the best I've ever used.
Snickers 9191 XTR D3O
I havn`t seen those before,although i havn`t been looking.I use the ones filled with little polystyrene balls,have you tried them? If so,are the ones you are using now a lot better?
dicktill said:
Related question for those who have pants with kneepad pockets: Do you wear out the outside of the pocket?
I've been using Blaklader mostly for years, some other brands too, never worn out the knee pad pocket. Usually they are cordura or something similar.
I've been using Patella-T kneepads since the late 90s.  You'll find varied reviews on them.  They're the most comfortable I've found, but they're hot in the summer, and when worn over jeans, they tend to slide down a bit from time to time.  I had to replace the gel packs a couple of years ago, but they're still going strong.
I wear snickers floorlayers pants,they are quite expensive,but i usually only change them when they have too much glue and stuff on them,the stitching above the kneepad pocket tends to go eventually,but the pocket itself never wears out
Thanks guys! Sounds like I should get some; my bluejean knees wear out in a couple of months ...
dicktill said:
Floorman70 said:
Just make sure you wear a belt,having 14 pockets,you tend to carry too much stuff in them and they get quite heavy  [laughing]
I have a piece of the 2mm foam underlay rolled up and shoved in mine at the minute. Those d30 pads look good and xpensive
Blaklader's cheapos in their pants were what I used. Hard to beat a comfy pair of pants with knee pads already there. Wore them through a long bout of bursitis in my left knee with no issues.
