BTW a Forrest 10 inch chopmaster 80 tooth blade WILL work in the Kapex. I had one bored with a 30 mm hole, tho I see no need for a Forrest blade since Festool has an 80 tooth blade which is slightly cheaper than the Forrest. I got the Forrest before I knew that Festool would supply an 80 tooth blade. The Forrest and Festool blades cut the same width Kerf - 2.75mm as measured by my dial calipers.
The chopmaster did a better job at smooth cut and fewer splinters when plunging through plywood than the standard Kapex blade. If not working with fine finish and tolerance the standard blade is only a small amount different than the 80 tooth Forrest blade.
The laser was a little off when I got my Kapex. The yaw and lateral adjustments were a little off. Soooo, I got out the trusty Bard Parker #11 blade and cut holes in the decal so I could make some adjustments. After about 20 minutes I could consistently split a pencil mark on both sides of the blade. I like that the laser lines are "thin" and precise. The laser line on my Bosch SCMS was fatter, was only on the left side of the blade, was not adjustable, and the saw cut about 1/32" from the laser. The Kapex can be precisely dialed in.
Now to the "dialing in".
The supplied festool manual says to use a 2.5mm hex wrench. That probably would have been great except I don't have one. The unreleased unofficial manual (thank you a whole lot! and I mean that sincerely) says use a #10 Torx bit. That works too -- except it won't reach into the holes that are under the template on the left side of the saw (even when the holes are nicely exposed by the above mentioned Bard Parker device [read Exacto Knife with #11 blade]).
So what to do, what to do? As luck would have it, my Radio Shack fancy screw driver set had a #10 Torx bit with narrow shoulders and all was solved. I would have loved Festool had they supplied a 2.5mm hex wrench, altho I must admit it may be hiding in some crevice of the Kapex that I have not explored. K-Y Jelly please!
Please enlighten me if I have missed some things here.
I examined the sawdust extracted from the Kapex by the 36mm hose. (A lot more fun than looking for ova and parasites in feces.) The dust was mostly quite fine, the kind that I would have inhaled. Good job there. The dust that escaped seemed be noticeably chunkier. Not real scientific but a definite plus. Again, not scientific, but I think the vacuum got about 90% of the dust, as advertised.
I used a Wixey digital angle gauge to check bevel angles. The saw was right on and consistent after I adjusted the little green arrow thingies, and very easy to return to 90 degrees. The bevel adjustment is waaay too easy.
I used a little Elmers Slide All dry lube to lube the fence but it was pretty smooth any way.
The crown molding wings went on easily and were aligned perfectly flat with the base of the saw.
PDG (Pretty Darned Good) What else can I say.
Best to everyone, from Las Cruces, NM
Joe
The width of the cut in my boards was 12 1/8" with the Kapex 260mm blade and slightly less with the 254mm Forrest Chopmaster.
