Kreg square drive bits in Centro-tec chuck
Jay Evans
Hi all-
I don't post very often, and I have never posted with pictures.
This is a trial post....
[attachimg=#]
Standard Kreg bit with about 3 minutes of work.
That's a 6" Kreg brand driver, inserted into a centrotec chuck on a drill I just got.  I have several other Festool drills.
Making this work takes about 3 minutes to do, works perfectly and is foolproof and well within the capability of anyone.
If this post works, and anyone is intrested, I'll post some more pictures with the method, and some other thoughts on driver sets and "installer sets"
Lets give this a try
Jay
Give a man a fish, feed him for a day, teach him how to fish- feed him for a lifetime
Thanks for posting Jay! I'm interested in seeing how you did this!
The biggest reason I have not bought a new Festool drill (sold my old C12) is they do not support VERY common driver bits, for instance 1/4", 5/16", and 3/8" Hex nut drivers, as well as the R2 square drivers. So, even though my C12 was a VERY nicely engineered drill, its lack of compatibility with North American drivers meant that I ended up using my Makita impact driver most of the time and my C12 sat in its Systainer.
Show me a way to use these extremely common bits in a Centrotec chuck and I'll go buy a C15 in February  [big grin]
Thanks again!
Best,
Here we go, but first we have to get on the same page about driver bits and the centrotec chucks and system.  My comments are based on my understandings of how the system works, plus my 20 years experience as a Journeyman tool and die maker and tool designer.
What actually drives the bits is the internal hex that is formed in the motor / drive shaft of the drill it’s self.  Because of that, you could stick any ¼ hex drive bit into a Festool drill, with no chuck at all.  Makes for a real short profile, but while the bit will drive well (keep in mind the bit drives from the engagement of the FLATS- not the corners) there is nothing to keep the bit retained in the drill when no chuck is used.  As I understand it, and as it appears in the current design the centrotec chuck has two functions.  The first is as a retention system for the bit which holds the bit in securely, but releases it quickly and easily without any tools or torqueing actions.  The second function it provides is a longer engagement of the outside of the bit or driver shaft, keeping the bit or driver straighter in a system that does not clamp onto the bit.  It also helps with concentricity of the bit, which is more important in drilling than in driving.
For the purposes of this specific application, concentricity of the bit is not important, as the bit can actually float in the drill, but will be positively driven by the hex drive.  Some will probably argue that driver concentricity is important (concentricity being the “trueness of the driver bit as it spins”) but keep three things in mind.  1- we drive fasteners at slow speeds, not full out open, 2- the shaft of the driver is supported concentrically at both end when you drive, the drill aligning the hex end and the fastener entering the wood acting like a stabilizer or live center at the other end, and 3- what do you think the chances are that with a hand held screwdriver (in use for 100s of years) that you would drive the tool perfectly centered in your hand.
What needs to happen to convert Kreg driver bits to work perfectly well with you centrotec chuck?
You need to get the outside dimension of the corners of the hex small enough to pass through the round opening in the centrotec chuck.  You need to shorten the hex length of the driver so that the shoulder where the hex meets the round shaft of the bit will fit below the ball detent in the centrotec chuck, thus retaining it in the drill assembly. You need to not disturb the hex flats if at all possible, because that is what drives the bit and transmits power.
In my tool and die days, I would have just put the driver bit in a collet on a tool and cutter grinder and taken down the corners of the hex to the proper diameter to fit in the centrotec chuck, which is believe around letter size N or .302”.  Since I don’t have access to that equipment anymore I made do with what I had, and did this on my Worksharp 3000.
[attachimg=#]
The pictures show the worksharp, with a wooden block and a hole drilled in the block that just fits the round part of the Kreg bit.  By aligning the corners of the hex with the side of the block that is flush to the drilled hole, and using shims to set the height to the surface of the disk (I use playing cards for lots of things) the “corners” of the hex cab slowly and precisely and repeatability be ground down until they fit just properly into the centrotec chuck and pass through without too much play.  Once you get the proper shim thickness, all you have to do is align each corner down to the bottom of the block and grind them off.  This is very consistent.  The pictures should make it obvious.  One you have the right shim thickness, it takes less than a minute to grind all six corners of the driver.  These corners do not do anything in the function of the tool, so if they are not all exactly the same, it doesn’t matter.  This process is very accurate though, and your results should be pretty much the same every time.
[attachimg=#]
[attachimg=#]
You can use the centrotec chuck as a sizing gauge.  Remember, you want to take of as little as possible, evenly from all corners and have the bit just slide through the bore of the chuck.  If you set this up correctly, you CAN NOT even touch the hex flats, so you don’t have to worry about that.
Once the modified hex fits through the centrotec chuck nicely, all you have to do is cut off the bottom part of the hex on the Kreg bits.  Cut at the very center of the radius between the two hex sections.  The bits are hardened, so you will need a dermal with a cut off wheel or any abrasive cut off wheel for steel.  I use a 4 ½ grinder with a cutting wheel.
Sand the sharp corner of the end of where you cut and that’s it.
Place the centrotec chuck on your drill, pull the green collar back, and the hex will slip through the chuck and into the hex in the drill shaft.  Release the green collar and the ball detent will pop back into position past the end of the hex, touching the round shaft of the driver, retaining the bit.  Try to pull it out.  You need to re-press the green collar back to get the bit to release from the drill.
Done deal.
I bought 5 sets of Kreg bits from Amazon for $25, and made the block, found my shim size, ground 10 hexes to fit and cut the ends of in less than 30 minutes.  I should have enough to last me my lifetime, but if I ever need to make more, I’ll keep my block and my calibrated playing card, and I will be able to do these in just a minute or two.  For non pocket hole square drive, I just use the wire detent bits in the Festool holder.
[attachimg=#]
[attachimg=#]
I took the pictures after I finished the run of bits, thats why there are already cut to length.  I ground the hexes full length, it makes it more stable.  Also the abrasive git was 120.  Worked perfectly.
I hope this helps someone.
Jay
I'll try the pictures again
[attachthumb=#1]
[attachthumb=#2]
[attachthumb=#3]
[attachthumb=#4]
Hope it worked- If not, I'll have to go back to the directions.
Jay
Lets try again befor I give up
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
I hope this worked-
Jay
Yeah Peter-
Sorry-
In my current job I have to explain a lot of stuff to engineering types and people who would like to be engineering types.
All I simply did was take some standard Kreg pocket screw bits, knock the corners off the hexes so the would fit through a centro-tec chuck and slip into the hex hole in the Festool (when the chuck was on the drill), and then cut the end off the hex end of the bits so that the driver bit catches in the latch which is worked by the green collar on the centro-tec chuck.
My long narrative is why it works and exactly how I did it.  You could even just knock the corners of the hexes with a belt sander (they are too hard to file) or a dremal.
I don't post often, but have been around for a long time and have attended several classes in Indy, so I have met many of you.  For those who know me they will tell you I get a little long winded.......and opinionated.....and..............
Hope this helps- it super easy to do, and solves the problem of wanting to use your centrotec stuff for pocket holes.
Jay
I stopped using the Kreg screws and started using the GRK one's.
Festool has the long torx driver covered.
Great tutorial Jay, thank you again for sharing! The pics go a LONG way towards illustrating your words.
Unfortunately, it looks like this reasonably quick and easy solution will not work for nut drivers, which do not taper down above the hex.  [sad]
Best,
Hey Jay!
Love your idea and will be doing this very soon.
Just a tiny reminder------- from the router class you talked about coming up with a solution for using the 2200 inverted and devising a way to fix the base more securely or at least with less slop. Did you ever tackle that?
Thanks.
Pete
thanks for the tip, I'll definitely be giving this a try.
BTW, the sanding disc looks like the ones that came with my worksharp but the iron support table your block of wood is sitting on looks custom. Can you give some details on that?  [big grin]
It's the Wide Blade Attachement of the Worksharp 3000.
Comes in handy when sharpening wide blades over 2" or other tools.
Like another member who replied to this post, I sold my (older) Festool drill and have not purchased a new one--due to this compatibility problem. I do a lot of pocket holes. I had my eye on the new T15, until I discovered this issue when I tried the drill at my local dealer (who was kind enough to warn me in advance--he is also a Kreg dealer, and this issue comes up all the time around here). Too bad, because I really liked the clutch--lots of finesse. So ho do I do pocket holes? In the shop I use two drills. For the holes I use a Milwaukee 3/8" 8A (corded) drill capable of 2500 rpm. This is a high speed, but it's recommended by Kreg to assist with chip clearance--it really makes a difference. I use this with the Kreg K3 pocket hole jig. I hook up my Festool vac to the chip ejection port, and leave the vac on maximum. I find that the suction provides a surprising amount of pull through the hole jig before there are any holes, which sucks the workpiece tight onto the jig. Very handy. To drive the screws I use a smaller, right-angle Milwaukee corded drill with a max rpm of 800. No clutch, but it's easy to control the speed and "feel" when the screw is tight enough so that I don't over-drive it. Faster and better feel than an impact driver. These two drills cost less than $250, so I was really on the fence about spending more than twice that amount for the T15 kit. The Centrotec compatibility issue was the deal-breaker for me. But I miss the nice clutch...
great idea,  but really now, should we have to buy bits and spend a few minutes grinding them down to fit, when thousands and thousands of square drives are used in the USA  not centrotec screws, not phillips, but square drive screws.
we should be able to buy them from festool that fit, it just make sense, if they made up 50,000 bits they would sell asap  if they made a 100,000 they would sell asap and a few extra days.
sounds like a great idea to me..
 I buy probably 100 square drive bits a year,  use um and I also loose um !  and I am just one carpenter in the bunch.
square drive is needed !
Strongly agree with the previous two posts. The reasoning behind paying extra for the Festool line is it is supposed to make your work easier, faster and smarter. I do not see how custom milling common bits to fit in a very expensive drill is fast, easy or smart.
For myself, I agree that using the Kreg Master system bench jig hooked up to a CT set to max is a great way to cut the holes, short of getting the Foreman setup. I had been using a Hilti corded drill to drill the holes until my van was stolen, now I'm using a my Makita LXT drill and just make sure I am using sharp drill bits. I DO like how Kreg has the bit sharpening service! Again, prior to my van getting stolen, I was gathering bits (I think I was up to 6), once I was up to 10 or so I was going to send them all in for sharpening at once to save on shipping. I think I'm on my second bit now...  [smile]
C'mon Festool, let's do this thing!!!  [big grin]
Best,
I bought some kreg bits and modified them per Jay's instructions. I used the worksharp to grid the corners and a 4" grinder to cut off the ends. It was quick and easy, great solution Jay! I would spend alittle time and money and modify the kreg bits rather than wait for bits or not use a drill that you want to use.
Curt
