mikey2
- Dec 17, 2009
After watching Paul Marcel's excellent video, I whipped this jig together in about 2 minutes as a proof of concept to modify a Kreg driver bit for the Centro-tec chuck. It holds a micro die grinder with a diamond bit to make the groove, much easier than using files. The brass screw is offset from the bit, and is used to set the driver bit to the proper height for the new groove. I will probably add a block later with a dado to hold a file for knocking off the edges of the hex bit.
[attachimg=#]
[attachimg=#]
