Laminate comes in different sizes
msw
just learned that laminate comes in different sizes for counter tops as well as for other projects.
I am doing my router table top.  When I tried to buy the laminate, the salesperson asked me what thickness do I want as well what the application would be.  So, as I was not experienced with laminate, I just mentioned to him just give me the usual that is used for countertop.  At the last minute, I changed my mind as the price varies greatly based on the size thickness and grade.
Can anyone recommend the best for my application of router table top. What thickness I should ask for .
Thank you,
Moataz.
Moataz,
You asked correctly it is referred to as standard grade plastic laminate. The other choices that I am familiar with are post forming and vertical grades. Both are thinner than standard grade and typically aren't even offered in DIY centers. Another thought if all you need is another piece for a router table top try calling any cabinet or counter top shop most, mine included, would have more scraps in more colors than you could imagine and would probably give them or sell very reasonably. It would save you buying more than you need. ;D
how about making a top with solid surface. If you are going to call a countertop shop, you might as well see if they have a peice of corian you could use. It's just another one of my crazy ideas. :o
Eiji
Eiji
      Say now,  a solid surface router table top. 8)    I have zero experience with that stuff.  I assume it would be attached just like for a counter top?  Which is?            I also assume it is easy to get it flat and keep it that way?
        Thinking down the road  , for when I build the replacement for my temporary table.
            Sorry Moataz, not trying to hijack your thread . But that solid surface idea soounds pretty cool.
