Leigh dovetail jig practice, hardware observations and MFS
James Biddle
I picked up the Leigh D4R a few months back and wanted to practice making some joints on scrap before using it on a real job. Here's what they turned into:
A simple storage box for my Festool MFT table using 1/4" toilet bowl bolts.  I was also experimenting with different ways to rabbet in 1/2" plywood on all of these.
I'm not sure what I'll end up storing here but it holds my remotes for now.  I started with "bullet" hinges, but they sagged a LOT.  I replaced them with a piano hinge, and although it's better, there's still some sag.  I put a catch on it, but I think I mounted it backwards.
This one is for storing my drill bits.  I used SOSS invisible hinges and these too have a little sag to them, even though I sized them to SOSS specs. I used a catch on this cab too, and mounted them opposite as the remote cab and I like it better.  I also tried some sliding dovetails that I sanded down a little for clearance to make them removable.  Not sure I like it all that much.  I used a french cleat to mount this one.  The back panel grain is sideways in order to use up scrap.
I mortised in the SOSS hinges before assembly.
This is the Festool jig I used for the mortising.  A 3/8" bit with a 5/8" collar made it easy to lay out.
Next up will be a cabinet for my turning tools and something to store the Worksharp.  Finally, here's how I'm hanging up the Leigh jig.
James,
Nice work. Practice makes perfect and you're well on your way.
