Deansocial
- Mar 14, 2010
what about a rim saw type affair?
What is a rim saw???Deansocial said:what about a rim saw type affair?
Deansocial said:sorry i meant ring saw
like this but for wood
http://www.priorityplant.com/Husqvarna-partner-K970RS-petrol-ring-saw/29.htm
Alan m said:i am deligted i didnt spend the money on a kapex (it was very close) and kept my dw718. laser system that works, dtent over ride that works, blade guand that can easily my pushed up out of the way (with my thumb) easily, 300 mm blade.
if only i could make it lighter and with better dc
Jonhilgen said:Alan m said:i am deligted i didnt spend the money on a kapex (it was very close) and kept my dw718. laser system that works, dtent over ride that works, blade guand that can easily my pushed up out of the way (with my thumb) easily, 300 mm blade.
Wait, you can't push the Kapex's blade guard up? I love being able to do it on my dewalt. Actually, I do it every time I make a cut!
Jon
So let me understand this.jmbfestool said:I did post this above but the entire post got deleted as I posted what I do to over come to problem on my kapex. Even though it might be against forum rules it's festools fault why this bad practice/unsafe use of a tool has to be done to actually use the kapex properly.
Jmb
mastercabman said:So let me understand this.jmbfestool said:I did post this above but the entire post got deleted as I posted what I do to over come to problem on my kapex. Even though it might be against forum rules it's festools fault why this bad practice/unsafe use of a tool has to be done to actually use the kapex properly.
Jmb
You are saying that every other saw manufacturer has their blade guard designed so that you can hold it up with your thumb while you cut?
I would really like to see that on their manuals/instructions that comes with the tool.
jmbfestool said:mastercabman said:So let me understand this.jmbfestool said:I did post this above but the entire post got deleted as I posted what I do to over come to problem on my kapex. Even though it might be against forum rules it's festools fault why this bad practice/unsafe use of a tool has to be done to actually use the kapex properly.
Jmb
Dont be silly they don't put it in the manuals as people will just sue! but they do it cus they know what people want
Is that a fact? or your opinion?????????
If you look around you will see most manufactures either made the guard so you can use your thumb to lift the guard or they have a trigger lever once pressed the guard lifts up with out the need to plunge the saw to lift the guard
I don't know of any miter saw that has something like that
Trust me manufactures do it for that very reason they ain't stupid they know people love being able to flip the guard up slightly using the thumb. It's safer because as they let go the guard returns back down! Unlike the kapex the method I am forced to use keeps the guard up permanently making it unsafe.
Trust you? Where do you get your info? again is this a fact? or something that you just come up with because you have no knowledge about it?
Most site workers I speak to and see on jobs use the thumb method when using their saws and it's one of the things they mention to me when using my kapex and they have a valid point.
Manuals? What's a manual? Never read them they are for novices.
Maybe you should start reading them!!
Jmb
Alan m said:dont be so hard on poor jmb. they dont print the manuals in his language.....
mastercabman said:jmbfestool said:mastercabman said:So let me understand this.jmbfestool said:I did post this above but the entire post got deleted as I posted what I do to over come to problem on my kapex. Even though it might be against forum rules it's festools fault why this bad practice/unsafe use of a tool has to be done to actually use the kapex properly.
Jmb
Jmb
Festoolfootstool said:Jmb you should consider the different specs of the same machine for different markets they do not get the same features on on stuff sold in the states, to me it looks like striped out stuff and metal parts replaced with plastic so its a stack it high sell it cheap mentality.
my 718 had no trigger lever for the guard it was a usa spec machine
makes you wonder how they sell any festool thoough
