jonny round boy
- Jul 21, 2007
Over the last few months I've been lucky enough to use Festool OFK500 trimmers for solid surface work.
It's not a tool I would ever have considered buying, but having used them quite a lot, I think I'd struggle to work without one now.
The only criticism I have is the depth of cut on the straight cutter (this trimmer uses special cutters so only the Festool ones fit):
The maximum length (NL) of cut is 8mm, so (allowing for a bit of adhesive that may need cleaning up) the thickest material you can trim is 1/4". I'd like to see a longer bit, so that 1/2" material can be trimmed with it. The motor is, in my opinion, capable of doing it, so why not make a suitable cutter? All that it would need would be to extend the cutting blades to, say, 15mm, and extend the centre fixing screw to suit.
Making this router capable of trimming 1/2" material would, I feel, greatly increase the market for the tool, too.
