rnt80
- Mar 30, 2008
I am currently working on a built in that has a 16' long mdf counter that is approximately 20" deep. I am having some difficulty in getting a consistent topcoat (I'm spraying KemAqua Plus tinted white) with my MiniMite3. I've sprayed it moving along the length and I've also sprayed it making a million passes front to back, making my way down the counter. Regardless of the direction I'm still ending up with stripes when look at the counter at an angle. I typically don't use any abrasives above 360 and was wondering if there was an abrasive that I could use, or work up to, that would provide a consistent , satin level sheen across the counter top. I'm not a novice when it comes to finishing but I'm certainly no expert. The only place I can spray this piece is in my backyard and here in AZ it is currently 65-70 degrees outside when I spray it. With all of this considered, plus the fact that I've already put down four coats on top of the primer, I'm not that optimistic that I'll be able to spray a coat without stripes. The back edge of the counter will be covered with uppers so that is why there is an unpainted strip along the back.
