LR 32 Hole Drilling Set with 1400 missing parts?
I just opened up my LR 32 Hole Drilling Set and it looks like there are 2 flat head screws used to attach the base plate to the 1400 router?  unfortunately these 2 screws were left out i guess?
what size are these 2 screws supposed to be?  once I know I'll go grab some from my local fastenal.
I just bought an LR 32 and and 1400. Haven't used them yet,  so I had to check to see if they sent the screws with mine. They did.  They are in a small zip lock bag located under the two clamps.  Also, in the bag were an allen key and a small folded up paper instruction safety sheet.  Hope this helps.
You might want to check under the insert just in case.
the bag is kinda small and so are the screws.
They would be easily missed while digging around looking through the parts.
In my 3- years of being a festool fan this is the first of I heard of tis happening so I would empty out the systainer...slowly including removing the insert, and even look around your shop floor too. Just in case you accidentally dropped it.
Not saying it couldnt happen, just saying that this would be the first time I hard of this happening.
