E
ericbuggeln
Guest
This weekend I started to build a 24W x 56L x 12 D frameless cab with two dadoed vertical partitions for a utility room we have remodeled. When it came time to break out the LR 32 I realized that the shelf pins would not line up if the sides were 24 inches and the partitions would be cut at 24 minus two thicknesses of ply plus 1/2 inch (1/4 top and 1/4 bottom).
What is the best way to get these to line up? Should I cut all pieces at 24, then drill shelf pins, then calculate how much to remove and divide it by two, so that exactly half is cut off the top and half off the bottom? Seems like a lot of room for error, but the best idea I can come up with.
Any thoughts or other types of methods would be appreciated, thanks Eric
