NERemodeling
- Mar 17, 2013
Hey all,
I am trying to accomplish several things and was looking to see if anyone else could lend some advice
I picked up an lr32 adapter plate and centering mandrel and would like to modify it to work with my bosch 1617 router (upon quick inspection it seems that i will be able to do this) has anyone else done something similar to this? how did you accomplish it
also i couldn't see myself spending $480 on the set (plus rail) so im trying to piece together my own with just the parts i need
i already have the adapter plate $115
from erock's awesome videos it seems that the lr32 connectors are very useful so i will buy those $27 (do you get 2 or 1 for the $27 ? )
i feel i can do without the edge stops... thoughts?
my big question is bits are there other sources for 35mm and 5mm bits? 1/4" or 1/2" shank size would be great to work with my bosch but i did find an 8mm bosch collet and also an 8mm whiteside collet adapter that are both around $10 each
i did find a 3/8 collet adapter on amazon, made by whiteside. could i just use a 35mm forestner with a 3/8 shank? i can get a nice carbide tipped forestner 35mm bit for around $20-30 instead of festools $75 and they are more available locally for when i need replacements
if the 35mm - 1 3/8" forestner bit would work then would a 1/4" forestner bit work for the shelf pin holes ?(obviously i would not be able to use 5mm shelf pins but i already have an imperial forestner bit set so that would be another savings for now)
do you need both the brad and the spear point bits or really only the brad point?
all totaled up and including a sys 1 i expect to spend $216 if i can use my existing forestner bits or $321 if i need the festool bits
thanks in advance for any input, advice and suggestions
John
John
