LR32 Set-up
skamin
Hi, I have been trying to set up the LR32 system and no matter how much I tighten or loosen these adjustment screws I can not remove the play between the plate and the rail.  Am I missing something?  Is there another way to adjust the plate (screws on top)?
thanks
Stan
Stan,
The two screws on the top are the mounting screws for the plastic adjustment block on the bottom of the plate.  There isn't any adjustment you can do with those.
When you tighten the slotted screw on the side of the plate can you see it push the black plastic out towards the rail?
Brent
When new, mine took a lot of turning until the black plastic began to engage the rail.  Take it off the rail and watch as you tighten the screws.
Thanks so much for the quick responses, upon closer inspection...the screws on one of the black adjustment blocks were a little loose, once I tightened them up, it worked perfectly.  I appreciate your help.
thanks
Stan
