J Jesus Aleman Member Joined Nov 12, 2008 Messages 206 Mar 11, 2011 #1 There is a pin at the bottom of the sliding stop flag on the LR32 stop. Is the pin 5mm in diameter? Thanks JGA.
Brice Burrell Member Joined Mar 13, 2007 Messages 7,325 Mar 11, 2011 #2 Jesus Aleman said: There is a pin at the bottom of the sliding stop flag on the LR32 stop. Is the pin 5mm in diameter? Thanks JGA. Click to expand... Sadly no, it's 6mm. The upshot is that if you use 1/4"/6mm ply back the pin will fit in the dado to keep a consistent 37mm setback.
