Dear FOG members,
I need a circular saw, and was eying the TS-55R. But a few days ago I went to a local retailer and who had the Mafell KSS-300. In France the KSS is a little bit more expensive that than the TS-55BEQR.
I love the petiteness of this saw for the far much better WAF but also since I'm somewhat clumsy with heavy tools.
So I have a couple of question, for users of both saws, about the following :
- I will sometimes need to cut kitchen worktops, and most of them are between 38mm and 42mm (that is 1.5" to 1.65") : is there a "standard/clean" way to cut this with the KSS (for instance by cutting both side of the panel) ?
- Is the KSS-300 compatible with mafell and bosch "standard" rails or is the flexible one the sole option for long cuts ?
- The plunge systems are looking very different : the system of the KSS looks somewhat awkward compared to the festools one (which looks very smooth). Is it true in real life ? Does the locked depth feature exists on the festools saw ?
- With the electronic brake and the automatic hiding of the blade, the festool looks safer, on the other hand, the KSS is lighter : would you say that one is safer than the other ?
- is there an easy way to make those angle cuts with the TS55R which look so easy with the KSS ?
Thank you !
P.S this is my first post but I read FOG since several months.
My only festool tool is the ps300 atm but I'm interested in the C12 set, the MFT/3 and the rotex (and of course the TS55R), I'm confident to get enough money to buy one or 2 of these tools at some point in the next decade
Thank you !
