I don't know which is worse, the Festool addiction or the Mafell disease...
I have several projects coming up that gave me the idea that I needed something like the HKC55. Decks, fence, shed siding, planter boxes, gazebo, etc. Lots of outdoor plans this year.
I first looked at the HKC55, it's Festool and relatively cheap. Then I read some of the complaints like lack of power, cut quality...
I realize I could get the corded version that probably has more power, but it takes away the convenience and portability.
Then I started looking at the Mafell KSS 40. I recently added the Mafell MT55 and P1cc to my toys, I mean tools. I've been super happy with the even higher level of quality/well though product vs. the similar Festool I've used. It's definitely been worth the extra dollars they cost to alleviate some of the frustrations I had with Festool saws.
My biggest concern with the KSS 40 is the depth of cut. 1 9/16" gets the saw through 2x material for the most part. A lot of my projects outdoors will have material that dimension or smaller - probably 90% of the material.
The HKC55 is over 2" which would probably cover 95%.
I know there aren't a ton of Mafell users on here, but was wondering if anyone had experience with the KSS 40?
The current 'special' pricing makes the saw much more temping. It's $999 with Flexi rail, charger and batteries. Just a couple hundred extra over the HKC55 set.
I've learned to 'buy once' even if it means the item that cost an extra couple hundred. Much cheaper than selling the first purchase to buy the one I should have gotten.
That would suggest getting the KSS 50 or 60. However, those are not on the same 'special' pricing and are quite a bit more costly when bundled with batteries. Not sure I can justify the cost for the extra cut capacity.
Plus, I think with the size of the KSS 40 I'd be much more likely to whip it out for projects.
I think I already know which way I'm leaning. Just performing my due diligence before getting the KSS 40 over the HKC55.
