lshah72414
- Nov 10, 2016
I have the same as Tom, except my batteries are 4.0 ah and only one extra blade. Closes without a problem.
Cheese said:Cheese said:It does work with Festool rails. There's a black Delrin insert held in with 4 screws that needs to be removed first.
I'm curious if the Mafell can be adjusted relative to the Festool splinter strip and if it can also be adjusted for fit on the Festool rail.
So here's the skinny with photos.
A photo of the sole plate of the MT 55 with the black Delrin insert still installed.
A photo of the sole plate with the Delrin insert removed, this will now ride on the Festool rail. The remaining black Delrin piece in the photo is an adjuster in the neutral position to fine tune the fit for use on a Mafell rail or a Festool rail. It's a rather clever twist.
[attachimg=2]
One edge of the adjuster contacts the Festool rail while the other edge of the adjuster contacts the Mafell rail. Obviously one size doesn't fit all. [smile]
Here the adjuster is tweaked slightly, potentially applying pressure to both the Festool rail slot on the bottom and to the Mafell rail slot on the top.
[attachimg=3]
And finally, here's the adjustment screws that will position the Mafell saw closer to or further away from the splinter strip. Again, one size doesn't fit all.
In my situation, I'll probably just adjust the MT 55 to fit the Festool splinter strip so it will work with the TSC & the HKC.
I'll then purchase a Mafell rail to use with the P1cc and the MT 55cc and the Mafell will cut the splinter strip as it is won't to do.
As a side note, the track engagement adjusters on the Mafell are really slick. They're detented so that each adjustment is a positive step and you can go forwards or backwards one small step at a time. Pretty slick.
As noted before, this saw really raises the bar on most every item.
The MT 55 blade spins at 6250 rpm vs the TS 55 blade at 5200 rpm.
The MT 55 blade has a kerf of 1.8 mm vs the TS 55 blade of 2.2 mm.
The MT 55 draws 1620 watts vs the TS 55 at 1200 watts.
The only nit I can pick is that the MT 55 does not have a riving knife. I'm thinking however, that the combination of the increased blade speed, decreased kerf thickness and higher amperage draw will negate the advantage of a riving knife as it will continue to soldier on cutting through the wood when the TS 55 has stalled out. We'll see...time will tell.
Michael Kellough said:Mine came with 5.5amp batteries.
Do you guys have the Flexirail in there too?
With the Flexirail it seems like not enough space but I didn’t push too hard.
Okay, I pushed pretty hard. It’s not going to fit with the Flexirail
JimmyFord said:Its got an electronic riving knife, if the saw starts to kick it shuts off- I havent tested this on mine, but jeff from timberwolf told me about the feature. I guess it was a very very big deal to get a saw like this in Europe made without a riving knife, so the technology was thoroughly tested...
Not at all. In Europe smaller circular saws up to 210 mm typically don't have riving knives.JimmyFord said:I guess it was a very very big deal to get a saw like this in Europe made without a riving knife...
I think mechanical riving knife has benefits. In a pinching situation it actually holds the kerf open and prevents the blade from gouging the martial too deep. Riving knife is thicker than blade plate, so it starts working before the blade is pinched and you can keep cutting instead of having the saw stalled.Tom Gensmer said:The electronic rising knife is great. I’ve only activated it a couple times, but it’s interesting to hear the saw just start to bog down, then the blade just slams to a stop, zero kick-back. Nifty.
Cheese said:The passive safety of the MAFELL MT 55 cc plunge-cut saw is also enhanced by the strict provisions of EN 60745-2-5 for saws without a riving knife. In the event of a kick-back, the standard requires that the sawblade fully retracts inside its housing within just 0.3 seconds. In compliance with the standard's provisions, MAFELL tested this safety feature more than 50,000 times.
Let's not confuse the matter. There is NO active retraction mechanism on MT55. It just has to unplunge in certain amount of time when you let it go. I.e. the spring has to be of certain stiffness. Knifless Bosch and Makita have to comply with the same standard.DeformedTree said:Hang on, are they saying on a MT 55 if the saw experiences kickback the blade retracts? De-plunges? That sounds saw stop like. I wasn't aware of this going on?Cheese said:The passive safety of the MAFELL MT 55 cc plunge-cut saw is also enhanced by the strict provisions of EN 60745-2-5 for saws without a riving knife. In the event of a kick-back, the standard requires that the sawblade fully retracts inside its housing within just 0.3 seconds. In compliance with the standard's provisions, MAFELL tested this safety feature more than 50,000 times.
ScotF said:The electronics stop the blade and since it is a plunge saw (like all other plunge saws) the blade goes back in the housing if an issue.
This could replace a TS75 except for depth of cut.
Bosch rails are identical to Mafell - just cheaper and blue splinter guard and Bosch branding vs. red and Mafell branding.
Hopefully TSO will come out with an adapter for the rail square to work with Mafell rails.
JimH2 said:Hopefully TSO will come out with an adapter for the rail square to work with Mafell rails.
jussi said:Would you consider it a replacement for the 75 as well? Besides the extra cut capacity would you be losing out on anything?
