bonesbr549
- Jan 1, 2008
Help, I may have a problem houston. First festool purchase yesterday was the ct33e & domino. I also got the upright handle for the 33e. I removed the handle from the box and I did not notice that the printed diagram sheet was loose in the box and fell out and under my table saw. Miffed (mistakenly) that no instructions came with the handle, I looked at it and the parts and it was quiet obious where things went and put it on. Here is the problem The handle was missing a part! the lower bracket that attaches to the bottom of the vac was fine. The upper black bracket was missing. I know now because I found the parts list. I put the bolts on the bottom no problem. Wen I attached the upperer white clips (that would have been coverd by the black missing part, the inside bolt pierced the outside wall of the shop vac. I found this out when I tried to attach the cord holder bracket and noticed there was no bolt hole. I scratched my head for a long time and then looked all over to discover the parts list paper sticking out from under the TS. Seeing the missing part on the diagram, I took off the handle and was going to just return it to rockler for a replacement when I saw the bolt had pierced the outer hull. Freaking out and using a lot of explatives, I opened the vac and noticed that it appears to be double walled and the interior was not harmed. Have I compromised this new vac? If so, how can I find out how to get the part replaced. What a bummer of a start to what was to be a great day with the new domino!
