Hopefully this is in the right spot within the forum. I'm sure someone will point me in the right direction if its not.
Had some remnants lying around at work, so thought I would make something that carries my two 1400 mm rails.
Going to sew on a zip and the two short sides in the next couple of weeks (paying customers always come first before my own stuff), essentially making an oversized pencil case with a divider.
Yeah I know one can buy em in the shop, but was in need of a challenge and all of the stuff was just lying around. My sewing skills arent fantastic and I have easy access to industrial sewing machines. Any excuse to work on my skills
Its simply 2 pieces of ripstop canvas, some foam for padding and a piece of tourneau material to keep the rails seperate. Figured something non abrasive in the middle would work well to stop the rails scraping against each other.
The hardest bit is to ensure the 2 zip halves meet correctly as one needs to sew each side separately. Going to use zip off the roll and simply "cap off" each end.
