Imemiter
- Sep 17, 2019
08G8V8 said:Do you have the part number of this hose adapter?
It appears to be Festool 202096. $22USD.
ThanksImemiter said:08G8V8 said:Do you have the part number of this hose adapter?
Imemiter said:I took them apart to see what you meant here... Very nice hack! And less than half the price of a Mafell dust bag.
Imemiter said:True enough. Less only because I already have the Festool bag.
Mike Goetzke said:Hartville has the bag and adapter for $55 so I bought the kit. I have two Makita track saws so I be able to see which works best Mafell or Festool.
slavi.yordanov said:I wanted to share a trick about the Makita Cordless too. The hose adapter from TS55/HK55 fits the Makita perfectly with a slight modificaiton. Unfortunately I don't have a picture to show, but once you get the adapter and open up the blade cover, it's pretty obvious what needs to be done. You also don't need any special tools, since it's plastic.
slavi.yordanov said:I cut mine where the 4 notches are on the Festool adapter. Just connect them together. I don't recall cutting in too deep. Never had a problem with that coming off. Wish I have taken a picture.
Why not get Makita bag (part # 122562-9) which is designed to fit Makita track saw.Mike Goetzke said:Don't think this Festool bag on the Makita is a total success
Svar said:Why not get Makita bag (part # 122562-9) which is designed to fit Makita track saw.Mike Goetzke said:Don't think this Festool bag on the Makita is a total success
But it's passive. Must be the tool itself that's inefficient. Everything that gets to the port ends up in a bag regardless of the brand. Unless Makita bag restricts air flow more than Mafell.Mike Goetzke said:The Makita bag is used on their miter saw too and I have one and is isn't very efficient at all. Mafell catches almost everything.Svar said:Why not get Makita bag (part # 122562-9) which is designed to fit Makita track saw.Mike Goetzke said:Don't think this Festool bag on the Makita is a total success
Imemiter said:Hmmm... thanks for doing all the prototyping, Mike. My nozzle gets here later today, I guess. I'm still gonna try it out.
