Had this Makita router laying around, so i fitted it to my cms, instead of using my festool router. It fits quite well.
I took the handle off of the router
I centered the router on the cms and then marked where the holes are that fix the plastic base to the router, this is what fixes the router to the cms, drilled and countersunk the four holes, ground off the little arrow on the bottom of the cms to allow the router to sit flat, the grey and black rings also needed some sanding back to make it all sit flat and flush, seems almost that the shape of the router is made for the this.
Dan.
Dan.
