I have an application in which I need to mill both sides of the surface of several small planks 7/8 inch thick, extremely smooth and perfectly flat. Ideally I need a thickness variation of the planks to be no more than .002 inches.
Is It possible to get this close of a tolerance by using the 1400 router with the 492728 Routing Slide and the MFS 700 Multi-routing template? If so, has anyone here actually done this kind of work and achieved those close tolerances?
I'm wondering if there is any amount of downward flexing of the routing slide due to the weight of the router when it spans wide distances approaching the 24" capacity of the MFS 700...
Or would I be better off buying a milling machine to do this kind of work?
