MFK 700 Advice
I need to purchase a new palm router.  I have used a first generation Bosch Colt for 20+ years. That router has served me well except wasn't a lot of bearing surface and one has to be on his game when doing round overs on narrow window stool, lest rocking off the edge pretty easily.  The only task that I currently use a trim router for is to ease edges with a 1/8"-1/4" round over or chamfer bit.
I'm having a tough time justifying the cost difference of the 700 vs another Colt (about $300). Can anyone tell me what they do with their 700s that could sway me to the green and black?  For edge treatment, I like the elongated base of the 700 to help the rock off effect, but that is not enough reason for me to invest. All advice is appreciated.
I use mine for edge treatment and template work (heavy rounding for table top or shelf), these are usually with bearing guided bits. Some grooves etc. is possible too. If I'm making new router table this summer, I'll rout panel grooves with MFK 700
It's easy to use, can be used in different situations. Attachments for different use cases..
Main question is, would I bought it again? Definitely yes!
Other people's view may vary..
Pros
+ enough power
+ very good dust extraction, you won't believe it unless you try it
+ easy and accurate adjustments
+ smooth start
+ quality
Minuses
- limited bit length in horizontal mode (you may need to do half-inch-sky's mod. or buy Festool bits)
- max 8 mm shank, it won't affect if you have another router (in Europe we use a lot of 8 mm bits. except UK)
- absolutely no visibility to bit, you won't see where it is. Make markings where to start and stop routing and rely on them.
- power cord goes upwards (in vertical mode) but DE hose goes in different direction, not big problem, but sometimes ugly
- You can't say it cheap. Just divide cost for 20 years ...
Vesa
I have 2-700's. They're very good at what you would like it to do.
I wish Festool would sell just the motor, I'd own a dozen and just swap the base. Cost would come down by the time you deducted the Systainer, insert, extra collet, and bases.
As to bases, you can easily make any size or shape base using various clear plastics from a big box store or other suppliers. Doesn't have to be pretty!
When I considered the 700 I found the biggest limitation was that it was designed for bits of very short length. This didn't work for me so purchased several Dewalt's for the price of one Festool. Have them set up for specific uses. Works for me and acceptable quality and function.
