Mfk-700 EQ-SET & SA-MFK 700 guide & Bits all *** Brand New ***
Status
Not open for further replies.
I have the following I would like to sell as a package but would consider selling the bits seprate.
basically it is the trim router with all the add on guide and the 4 festool bits made for it.
Asking $750 shipped to your door in US
Paid over $800 couple months ago.
I just decided to go another direction everything is bran new not even taken out of the box.
Below is a more compleat discription and prices.
[attachthumb=#][attachthumb=#]
MFK-700 eq-set ($525)
SA-MFK 700 guide (48.50)
Edge Trimming Chamfer Bit w/ Ball Bearing
Product No. 491026 - ($36)
Ideal for use with MFK 700 or OF 1010 for trimming laminate (Formica). This router bit features two cutters a short two flute straight cutter and a short 45 degree chamfer cutter. The two cutting profiles allow the user to trim laminate back flush with board edge while putting a slight chamfer to relieve the laminate edge. This two-in-one bit is bearing guided to allow guidance from the substrate material. The bearing is coated to prevent damage to the material.
Chamfer Cutter 45 degree
Product No. 491669 - ($45)
Ideal for use with MFK 700 and the 1.5 degrees Horizontal Base for trimming edge banding and creating a slight chamfer break to the laminate. For filing of edge banding and creating a chamfer where the laminate and edge banding meet. By trimming both back there is not hard corner edge. This helps to prevent the laminate or edge banding from getting snagged and becoming chipped or peeled off of the material.
Roundover Bit w/ Ball Bearing
Product No. 491009 - ($48.50)
Ideal for use with MFK 700 and OF 1010 for trimming of laminate. The small 2 mm (5/64") radius produces a slight round over on the material to alleviate a crisp hard edge as well as being pleasing to the eye and to the touch.
Status
