My MFK 700 Router keeps shutting down while under load.  I was using my router to rout some 1/4"wide x 1/4" deep dadoes in some 1/2" Baltic Birch Plywood, when my router started to turn itself off automatically.  I thought maybe the switch vibrated off, but when I turned it on again to continue to rout, I had my thumb on the switch and it still shut down.  This does not make any sense to me because prior to this I had just completed around 20 feet or so of routing dadoes with the same 1/4" Undersize Plywood Bit (Rockler, 2 Fluted Bit, Brand New) and an 1/2" Undersize Plywood Bit with no problems.  I also had no problems trimming some laminate countertop material a few day earlier.  When this problem occurred, I was using the edge guide, and thru the vent holes in the routers body I noticed some abnormal amounts of arcing.  There was very little arcing that could be noticed when I turned the router on and let it run with no load being applied to the bit.  But, when a load is applied you can see quit a light show.  This router is only a month old, bought when Festool had there router deal.
I will be contacting Festool on Monday, but wanted to know if anyone come across this same or similar scenario.
I think Festool has great tools, but a bit bummed out about this.
Thank You,
K. Moura
Thank You,
K. Moura
