ssbothwell
- Mar 27, 2015
hi. i am using my mfk700 with the 0 degree base to flush trim 1/2" thick edging on plywood panels. i already glued up all four sides of the panels assuming this would be no problem. the edging is currently about 1/16" raised above the panels.
when i get to the corners i am not able to pivot the router around the corner. is there some trick to this or is 1/2" deep edging to much for the mfk700?
