So I tossed the first real challenge at my brand new MFK700 today. I’ve tested the machine on some thin edge banding and it worked fine but today I needed to route a slot in a place which I couldn’t get to with my OF1010. Nothing crazy - 100x20x6 (length/width/depth) slot in plywood using a 14mm bit.
I installed the brand new router bit I have purchased for this project and got to it with the router set to medium speed.
The first slot went just fine but while cutting the second slot, the router stalled. I backed off and it came back to life but before I could make contact with the material, it started stalling again.
I proceeded to test the router in free air and it kept exhibiting this problem, i.e. stalling then coming back to life and then stalling again.
We are talking max 5 minutes of run time here, so I highly doubt the router could have over-heated, nor was any part of it hot. After resorting to chisels instead of my new Festool toy, I retested it in free air and now it seems to work properly.
Does this seem normal? Could I really have overloaded the router with this cut?
