I'm toying with the idea of buying an MFS 700, but would have liked the opportunity to use it to cut bigger than the 600mm x 300mm afforded by this option.
I am therefore considering buying the MFS 400 kit along with a pair of 2.0 mtr additional rails. I am then thinking of cutting the additional 2.0 mtr rails on my Kapex (with an Aluminium cutting blade) to give a pair of 750mm rails as well as leaving a pair of 1250mm rails (minus the kerf of the cut).
This would then give me a range of pairs of rails of 200mm, 400mm, 750mm and 1250mm and would allow me to make cuts up to 650m x 1150mm but enable me to use the appropriate sized rails for the cut required.
Has anyone else done this and is the cutting of the large rails likely to be a problem?
Thoughts?
Thoughts?
