- Feb 8, 2007
i will probably order one as they are coming out may 1st. that way I can have one set up at my home show, and one for jobsites.....
bamo@xs4all.nl said:There is a temporary English webpage on WALKO with demo!
http://www.walko.nl/EngTmp.htm
greg mann said:T slots may be ubiquitous (common) but there are some limitations to them that the v groove can overcome. Automatic alignment to the groove is the first that comes to mind. Also, you can remove and replace the fence without disturbing anything else along the rail.
Just agreeing on what a portable table should look like is impossible. There are so many variables in workbench design that they would probably please no one with whatever they came up with. 'Why did they make it so tall? Why did the make it so short? I need two inches more width. It's two inches too wide to fit in my workspace......'
Michael Kellough said:...I'm contemplating making a Mini-MFT based on the observation that anything not directly required for supporting the fence and guide rail is just outfeed/stock support and doesn't need to be directly connected to the tool alignment stuff..
Ned Young said:Michael Kellough said:...I'm contemplating making a Mini-MFT based on the observation that anything not directly required for supporting the fence and guide rail is just outfeed/stock support and doesn't need to be directly connected to the tool alignment stuff..
2 ideas come to mind:
A narrow MFT, where the long dimension is parallel to and beneath the guide rail, and the narrow dimension is just 2 or 3 times the width of the guide rail.
An L-shaped MFT, where the short end of the L is is parallel to and beneath the guide rail, the vertex of the L is nearest the guide rail pivot, and the long end of the L pointing off to the left. A fence of full length could be supported, and the user could get as close to the work as he wanted. Strongly orientation toward right-handed users.
Both designs would result in the user working beside the table, not in front of it.
Ned
