This is a somewhat more elaborate auxiliary fence. It can be used for support on the other side of the guide rail, or can be used as an aid to clamping, like Jerry Work shows with his MFT manual. These pics had been posted on the old site in the text I wrote about design considerations for the large MFT, but I never moved the text and pics onto this site.
The first pic shows the basic construction--slots are bored at 96mm centers to match the grid of holes on the MFT table top. The slots are a little longer than 96mm in order to give a little more flexibility when putting them into position. The width of the slots is chosen to accommodate the size of the t- bolt that will be used to fasten the fence to the table. The top of the slot is a little wider, in order to seat the head of the t-bolt and keep it from turning.
The second pic shows that the auxiliary fence may be mounted on the side rails of the MFT by use of spacers made of 12mm (1/2") MDF. The "bolts" were shop-made from a hardwood dowel with a threaded insert, but store-bought star nuts would work as well or better, IMO.
For those who want to use Incra fences, it would probably be pretty easy to mount one on one of these auxiliary fences.
Hope this is helpful to someone.
Regards,
John
