Michael Kellough
Lot's of people have wished for a taller MFT, and now that it is on the horizon (other?) people are sharpening their pipe cutters.
I often use both 800 and 1080 MFTs on the same job for different operations. It is often best to keep them far apart because they are the same height. A jig set up on one MFT would interfere with the board sitting on the second MFT. When space was tight I've had to jack the right hand MFT up higher so the board would clear the left hand rig.
Putting the MFT3 on the right of a two MFT setup would still allow the left hand MFT to act as a support table with the addition of a simple 2" shim block and still allow the left hand MFT to be configured for other operations. For example, the left hand MFT could be clamping up a small frame and still allow long boards to pass over the rig while being trimmed on the MFT 3.
