AstroKeith
My workshop is small (its a standard single 60's UK garage - not even big enough for a modern car), and my router station tends to stay in the middle. It gets used a lot as a router, but also as a general purpose bench as I can get to three sides of it.
Having just replaced the tops on the built in workbenches that run the full length of each side wall, I had 1/3 sheet of 18mm birch ply left over. This has now been made into a MFT style 'lid" that fits over the router station (don't need to remove slides, fence or lower cutter) It fits snuggly on to the table top and is secured by two M8 screw/knobs that mate with the router fence slots.
I'm now thinking of making a thin 'sacrificial" cover sheet that I can use when glueing or applying finishes.
I used the UJK Parf guide system to mark out and cut all the holes in this and the build in benches. Can highly recommend it.
