Jerry Work
- Jan 16, 2007
It is the preferred method for dealing with wood movement. What I mean by flat panel is that I book match all my solid wood panels at 10mm thick so they fit into the 10 x 10mm grooves in the rail and stile components. I leave the panels flat instead of building them thicker and then routing or shaping an edge profile which leaves the center high, the edges 10mm thick to fit into the grooves and some form of decorative profile in the transition between thick and thin parts of the panel. That is what is commonly referred to as a raised panel. Interestingly the Shakers used a raised panel on the insides of their doors, but left the panel flat on the front side where it showed.
Jerry
Jerry
Dave Ronyak said:Thanks, Jerry, for listing your specific choices of router bits and why you chose them! I'm not certain I understand what you describe as a "flat panel" construction compared to "raised panel" construction. I know what the latter is and thought that a proven construction to deal with the expansion / contraction movement that naturally occurs when working with solid wood.
Dave R.
