woodferret
Don't forget digital calipers are kinda crappy. I know it says xxx accuracy, but most of the time, they meant precision - not accuracy. It also matters on how you hold it. As for the linked 5-cut PDF, also keep in mind that when you trim off that 24mm piece, it's not fence supported, so it may wobble a bit before falling off. I've had the dreaded toe-in/out at the end of those offcuts before.*
* note that cut under the rail is still fine, just the offcut moves into/out of the blade.
