MIDI hose sleeve.
Stanleywc
I have a Midi with the factory 90 degree extractor connector. I purchased the 452 892 connector not realizing the hose was tapered and was actually 32 mm. Is a straight extractor end connector available for the 32 mm end?
  Thanks, Stan
Are you using the sleeved hose?
If you're trying to use a 90 degree extractor end for the sleeved hose, Festool does not offer that connection.
Are you trying to connect the sleeved hose to the supplied Midi hose ?
Eric
I may not be understanding this situation correctly, however, I'm using a 27/22 sleeved hose successfully on a Midi complete with the 90 degree end termination.
I have the 90 degree connector that came on the non-sleeved hose...I am wondering if I can get a straight extractor end for it so that I can connect it too my 36 mm hose.  Thanks for the replies.
You can actually get a 90% fitting from Oneida that is anti-static...Oneida AHA000004, I use one with the Midi I have my Dust Deputy sitiing on.
