davidinkew
- Nov 17, 2013
The house we're building has a prefabricated steel stair which will receive a 170mm deep solid timber handrail of 28mm thickness. We will weld tabs onto the top edge of the stair to locate the handrail and support it laterally. Our plan is to Domino 70mm pockets into the bottom edge of the handrail.
I would love to find a steel bar profile which resembled the rounded profile of the Domino. Likely we'll just use a thick piece of flat bar, but is such a thing out there? What would it be called?
Really keen to use the Domino system in new ways. We've already CNC cut a kitchen which uses Dominos for rapid assembly, but steel Dominos would open up a load of other possibilities.
Thanks,
David
Thanks,
David
