leakyroof
- Mar 23, 2011
If you have Alloys, it might be time to have the Tire dismounted and the rims wire brushed of corrosion build-up at the bead area. Then, bead sealer is applied to coat the hills and valleys of metal in the bead section. The more moisture the rims get internally , the worse the build-up is.Michael Kellough said:I keep my M12 inflator in the car because I need it so often. I seem to have a bad rim. It’s amazing how much air you can get out of a little 17wh battery.
