Milwaukee M12 Fuel right angle die grinder
rvieceli
Carbondale Illinois
I was going to write up a short review of this new right angle die grinder from Milwaukee but after using it yesterday and today to de-burr and clean up some mild steel, I’m just going to say that if you work with metal in any of your process just buy one.
https://www.milwaukeetool.com/Products/Power-Tools/Material-Removal/Angle-Grinders/2485-20
It’s generally available from most Milwaukee dealers online. right [member=48572]Shane Holland[/member]
It has four speeds from 10,000 to 24500 rpms. Has a 1/4 inch chuck and takes all the M12 batteries although a higher capacity one is better like 4.0 or 6.0
Paired with 2 inch rolocs it is a joy to use. Light, one handed operation and good control over working with a bigger angle grinder.
Quiet compared to a regular grinder and doesn’t have that annoying dentist drill whine like most air powered die grinders.
Ron
Thanks for that!  I was debating that or the extended ratchet during the last promo toolnut had.  Ended up with the ratchet, but I’ve convinced myself I’ll have the die grinder when the next promo rolls around.
