HarveyWildes said:
vkumar said:
Just curious. When driving small screws do you have fine torque control so that you do not overdrive the screw?
Yes. It has both a torque selector collar and a 2-speed switch. In addition, the trigger is pressure sensitive variable speed. The manual includes the torque specifications for the settings of the torque selector collar. (see https://documents.milwaukeetool.com/58-14-2505d2.pdf.) I used the torque collar for driving, but the smallest screw I used yesterday was about 3/4" #6. However, I wasn't even close to the lowest torque setting.
When driving small screws, a lot depends on how you pre-drill, what wood you are using, and the screw size, length, material, and lubricant, if any. However, the Milwaukee tool has all of the capabilities that I would expect in a driver designed for smaller screws.
I think what [member=163]vkumar[/member] meant was if it has electronic torque compensated speed control.
This differ vastly from variable speed control by the trigger itself.
Electronic compensated speed control works like this:
Imagine you will screw a 5x70mm wood screw into soft wood, without predrilling. Once you press the trigger it starts to rotate at a (presumably) low speed to maintain control at start.
“ETSC” will monitor your trigger switch setting, and continue the speed you started with, the longer the screw is seated deeper in the wood the more resistance it gives, here the “ETSC” comes in, it compensates the force or torque to maintain the almost exact speed. You will then not need to alter more pressure to the trigger, the electronics does this for you.
This gives excellent torque and screw control with both delicate small and large screws.
This is why I chose the Makita drills in the first place, as they also incorporates “ETSC” in their CXT 12V line. Bosch for example, do not in their 12V line, which I had but sold in favour of Makita. I’m not familiar with Festool TSX/CSX if they have this type of electronics, but I have the C18, and this has excellent “ETSC”. I will not buy any screw drill that not have ETSC. The Makita CXT 12V BL is an excellent “fine” tool for delicate work, and it even have enough power to leave my 18V drills behind to only special occasions.
