Cheese
Food for thought...the pallets I'm familiar with have 2" x 4" stringers while the deck boards are usually 5/8"-3/4" thick and usually all are made from oak for durability.
RKA said:If you find a need for something bigger, get the unimog.
hdv said:So, I ended up with a whole different set of saws than I had in mind when I asked you guys for advise.
How you hold the driver is different than a regular impact or drill. Put your thumb and forefinger pointing towards the tip of the drill/driver and use your middle finger for the trigger. Now hitting the button with your thumb doesn't require any grip readjustment.hdv said:The balance and weight are great. I really like how this drill feels in hand. The forward/reverse button issue some mentioned is no issue to me. My hand is just a bit too small to reach the button on top without changing my grip, but I don't think that will detract from it's usability.
Roachmill said:I just couldn't get on with the fact small wire bits almost disappear into the chuck and are a fiddle to get out. Quick change bits should be quick to change. Also, not physically holding the bit in place was a let-down. Wera Rapidapters are great in that they hold any kind of bit solidly and are easy to change bits but, for a drill that's meant to get in to tight spaces, I don't want to have to swap it in and out.
The Bosch Flexiclick won the battle between the two drills pretty easily. It's not as pretty but it works... and works well IMO.
CarlsonCarpentry said:No impact driver or bit holder for drills are meant for those little 1” bits. The 1” bits are for chucked in bit holders. For chucking bits straight into drill/drivers you need 2” or larger bits.
When I went to use my driver yesterday I realized you might not know about the secret feature. So here it is...Remove the 1/4" chuck, and insert your tip directly into the end of the 1/4" shaft. It already has a magnet for holding the bits, and it will hold a shorty bit. Happens to also make the tool shorter.hdv said:Before I do that I'll try a trick I've used before. I must have a rare earth magnet of the right size somewhere. If I can find it I'll drop it in the chuck and see if that improves the situation.
