Mounting the MFK700 on the side of a MFT or MFT3 plus making a guide rail sled
Jerry Work
Hi all,
I just updated the tutorial on my web site that describes how to mount the MFK700 to the side of either the MFT or the MFT3 and how to build a guide rail sled to use that router with a guide rail.  What I added was information on how to make a micro-adjuster from the Fine Adjustment piece from the 1010 router (488-754).  With this adjuster in place the height the bit tip sticks up above the surface of the table can be easily set in 0.05mm increments (about .002").  No modifications are required to the table, the router or to the Fine Adjustment piece.  The downloadable .pdf is located at:
http://jerrywork.com > tutorials
Jerry
Jerry,
YOU are fantastic.  You wrote a fine report on the MFK700 and Festool USA doesn't even have the tool on their web site.
Al
