Crazyraceguy
- Oct 16, 2015
Hans Mertens said:I bought a 5000 many years ago, first thing I did when it arrived was to take it to the chopsaw and make it a 3300/1700.
The 3300 is just long enough for cutting sheetgood up to 3050mm which is a standard size here.
Similar the 1700 works for crosscutting 1530mm wide sheets.
Never had any regrets doing this.
Wow [eek] ok. It's wild that someone would cut on one of those? at the cost of them? The 3000 is bad enough.
10' sheet goods are available here, even as big as 5' x 12', but hardly common. Outside of a cabinet shop, you're just not going to find them. Places that use material that large, generally have some way to handle it. Panel saws, etc.
Handling one of those things has to be a challenge. I can see flooring guys straightening seems with it, but what else?
