Gary in Texas
- May 16, 2014
My MFT/3 top equates to the above dimensions, however, hole pattern is 11 x 7, not 11 x 5.
Baremeg55 said:My MFT/3 top equates to the above dimensions, however, hole pattern is 11 x 7, not 11 x 5.
DanDan Clark said:One question about weight and stability... Have you used the bench for any hand tool work like planing, scraping, etc where a big solid bench is usually required? How well did that work out? Any mods you would make if you did a fair amount of neanderthal work?
Tinker said:I have only this morning stumbled onto this thread. I am much impressed with so many ideas put into only one space saving table. I have been looking at a lot of different tables over the past year, or so, and yours seems to address more than any other single table i have looked at. I especially like the way you have attached the end extensions.
I would also like to know if you find the table solid enough for hand planing. I think it is probably plenty solid for power plane, as are my MFT benches (1080/600/3). They are solid enough for planing as long as the wood cooperates by offering minimal resistance. Hard wood is a different story.
Also, the pipe you have the top mounted on, is that adjustable? The reason i ask is that I have very little headroom in my shop. I also have a problem with bending my body to work on a lower table. My MFT 1080 and 600 are low enough that when working for a short time, and bending over, even to use the TS 55, i can hardly stand up afterwards. I do not have overhead space to assemble large projects. The first thing I noticed when looking at your masterpiece was those plastic pipes hold the table. I have been looking at several methods for table height adjustment. Those pipes appear to be a good trade off as they might be very adjustable, but i wonder how strong. They certainly add a lot less weight than boxing with ply wood or hardwood.
I also like your boom arm design. Presently, I store excess hose & power chord overhead by suspending loosely with bungee chords. I just slide excess back overhead to keep it out of the way. Depending on whether I am ripping or crosscutting, i relocate the bungees and or feed excess/extra hose length in and out over head. I like your idea and will try experimenting a little. I used the Festoy boom for a couple of years but with so little headroom and heat ducts, light fixtures, electric lines and etc, the boom was more of a hindrance than a help.
I have bookmarked as I do not want to lose any of your ideas. thanks for sharing.
Tinker
Bob,squarecut said:DanDan Clark said:One question about weight and stability... Have you used the bench for any hand tool work like planing, scraping, etc where a big solid bench is usually required? How well did that work out? Any mods you would make if you did a fair amount of neanderthal work?
I have only used it for light hand planing of soft woods both surface & edge and have found with all four casters in full lock that there is negligible movement of the bench - almost none at all. That said, I do not believe this design would lend itself to Neanderthal work. Due to it's case construction and wing alignment dictates, I do not see how any additional beefing up could be employed to transform it into anything close to a solid bench. I think we are talking about two separate animals here.
Bob
That is a FMT Pro Mortise & Tenon Jigjohn5mt said:Square...whats that vertical looking jig with the dewalt plunge router?
